Carrello
Il tuo carrello è attualmente vuoto.
Vai a fare shopping
  • robotic lawn mower
    robotic lawn mower
    An Autonomous Mower Mowing up to 6 Acres
    Max. Coverage
    20 in
    Cutting Width
    Applicable Slope
yarbo lawn mower
Find the Suitable Lawn Mower for You
Answer four quick questions to find the lawn mower that performs best for your yard.
Optimal Grass Types for Lawn Mower
Cool-Season Grasses
Kentucky Bluegrass
Kentucky Bluegrass
Perennial Ryegrass
Perennial Ryegrass
Fine Fescues
Fine Fescues
Tall Fescue
Tall Fescue
Customize the Edge with Vision Precision
Sets ideal boundaries to fit each part of your lawn and cuts right to the edge with high level of precision.
Ride-On Edge Cutting
Yarbo automatically mows ride-on to the edge, leaving no uncut grass behind. No complex setup is needed for a neat and complete finish around your lawn.
Mow with Edges Coverage
Yarbo Trimmer helps get those hard-to-reach spots along obstacles. It’s a simple add-on made to complement your mower, contributing to a more complete and manicured cut.
Precise Mowing Under Trees
Experience smooth navigation with Yarbo’s reliable network, supported by binocular cameras, side cameras, RTK-GPS, IMU, and ODOM sensors.
Adaptive Obstacle Detection
Smarter Sensors for A Dynamic Environment
Yarbo smoothly navigates around obstacles to keep a consistent mowing pace and minimize unnecessary stops.
Smarter Lawn Care, Redefined with Precision
Zone Management
Define up to 150 zones in the app to match your lawn’s layout. Various zones can be adjusted independently, handling different grass types, slopes, and obstacles with ease.
Zone Management
Intelligent Path Planning
Yarbo’s advanced navigation system creates efficient mowing paths, helping to reduce overlap and improve coverage for a well-kept lawn with less effort.
Creative Stripes
From classic straight lines to eye-catching patterns, Yarbo’s precision cutting enables custom lawn finishes—adding variety and a creative touch to every pass—bringing variety and a touch of creativity to every mow.
Creative Stripes
Effortless Wire-Free Setup
Revolutionary AI-Assisted Mapping. Simply drive Yarbo around with your smartphone to create a virtual boundary with zero wires.
Built for YOUR Lawn
No matter the terrain-hills, bumps, slopes, tree roots, flower beds, or pathways-Yarbo
navigates it all and gets the job done.
Adaptable Design for Different Terrains
Yarbo adapts to varied terrains with its flexible mower frame, traction tracks for slopes, and steel skid shoes for smooth movement, helping maintain stable navigation and consistent cutting.
Torsion-flex Mower Frame Torsion-flex Mower Frame
Multi-Terrain Patented Tracks Multi-Terrain Patented Tracks
All-Steel Skid Shoe All-Steel Skid Shoe
All-Steel Skid Shoe
6 Acres Coverage
Up to 120 minutes of runtime and dual 20-inch cutting discs let Yarbo cover lawns as large as 6 acres. The auto-charging system keeps it going until the job is done.
Industry-Leading Cutting Width Industry-Leading Cutting Width
High-capacity Battery High-capacity Battery
Auto-Recharging System Auto-Recharging System
Yarbo’s dual discs, each with five blades, deliver a 20” cutting width for fast, efficient Lawn care.
Yarbo’s battery mows up to 1012 m² (0.25 acre) per charge—three times the industry standard.
Yarbo returns to its charging station at 20% battery level and automatically picks up where it left off—no input required.
A Quick Look at What Yarbo Can Do
Our users shared their lawns — and Yarbo delivered. Yours could be next.
@Scott Grams
"I'm working hard mowing today."
@Gabriele Malvicini
"Wonderful
From Italy"
@Chad Albrecht
"Preseason stripe practice is going really well! Bring on the greening!"
@Sam Marie
"We have so many different kinds of wild grasses that get out of control when we don’t mow. "
@Sam Marie
"✅ WET grass"
@Will Seale
"It's great having Yarbo mow around the playset! I'm using the deadend mode to stack up the paths."
Yarbo Mows with Reliable Navigation
Mow with Reliable Navigation
Yarbo Mows with Ultimate Safety
Mow with Ultimate Safety
Yarbo’s spatial AI system, equipped with 6 cameras, 4 ultrasonic radars, a front bumper and an advanced AI algorithms, ensures safe mowing by efficiently identifying obstacles.
Yarbo Mows without Edges Uncut
With precise edge detection and the innovative robotic trimmer, Yarbo ensures a clean and complete cut every time, eliminating the need for touch-ups.
  • Is Yarbo suitable for large lawns and properties?
    Yarbo robotic lawn mower is designed for large lawns, covering up to 6 acres. On a single charge (from 80% to 20%), it can mow for approximately 120 minutes, and recharging back to 80% takes about 90 minutes. In a typical day, Yarbo completes up to 7 mowing cycles, each covering around 0. 25 acres. If mowing twice weekly, as recommended for grass health, Yarbo can cover up to 6 acres per week.
  • Can Yarbo handle steep slopes and complex terrain?
    Yes. Yarbo robotic lawn mower can handle slopes up to 35 degrees (70%) and navigate complex terrains with features like ditches, trees, and ponds. Its tracked drive system and powerful motors enable strong performance on uneven and rugged lawns.
  • How’s the mowing quality?
    Yarbo robotic lawn mower features dual floating cutting discs, each equipped with five razor-sharp blades, providing a 20-inch (50 cm) cutting width and adjustable cutting heights from 1.2 to 4.0 inches (3–10 cm). This design ensures a clean, even cut across a variety of grass types.
  • How do I install Data Center for optimal performance?
    Installing the Data Center Set involves three main steps: place the Data Center in an open area with at least a 120° clear view of the sky, connect it to your router using the included 30-meter Ethernet cable, and power it on. Yarbo app will guide you through the final setup to ensure everything is working properly.
  • Where should I place the Docking Station?
    The Docking Station should be placed on a flat, even surface in a clear, open area free of obstacles. Ideally, position it near the center of Yarbo’s working area so it’s easily accessible from multiple directions. Make sure it’s located where there is a strong RTK signal to help Yarbo dock accurately, especially when the battery is low. Regularly check that the station remains level, clean, and securely connected for consistent performance.
  • How does Yarbo Robotic Lawn Mower ensure precise navigation?
    Yarbo robotic lawn mower for sale ensures precise navigation by receiving RTK correction data from the Data Center. The Data Center itself connects to your router through a wired Ethernet cable to maintain a reliable network connection. Proper placement of the Data Center with a clear sky view helps ensure consistent signal quality.
  • What about battery life and coverage per charge?
    Yarbo robotic lawn mower delivers industry-leading battery performance, providing up to 120 minutes of mowing per charge (from 80% to 20%) and covering approximately 0.25 acres (1,000 m²). When using the full battery capacity (100% to 0%), it can cover up to 0.43 acres (1600 m²). Yarbo automatically returns to the charging station at 20% battery, takes about 90 minutes to charge back to 80%, and then resumes mowing without any manual intervention. This efficient and battery-friendly charge cycle allows Yarbo to cover up to 1.7 acres per day and 6 acres per week when mowing twice weekly, as recommended for lawn health.
    In addition, Yarbo features an advanced battery management system with protections against overheating, short circuits, overcurrent, and overcharging. It also adjusts charging modes based on real-time conditions to ensure optimal performance and safety.
  • How well does Yarbo Robotic Lawn Mower detect obstacles?
    Yarbo robotic lawn mower for sale features a sophisticated obstacle detection system with 6 cameras, 2 ultrasonic sensors, and a three-sided smart bumper. Its spatial AI uses advanced algorithms to distinguish between grass and obstacles such as trees, garden decorations, toys, passersby and pets. For large or stationary obstacles, it's recommended to set them as No-Go Zones. Yarbo will then use smart path planning to navigate around them while continuing to mow edges accurately with its centimeter-level, wire-free navigation—improving both mowing coverage and efficiency.
  • What maintenance is needed for blades, tracks, and general upkeep?
    Yarbo robotic lawn mower requires simple, regular maintenance to ensure optimal performance. Blades should be replaced approximately every three months with heavy use, or sooner if cutting performance declines—no special tools are needed. Tracks should be cleaned and lubricated regularly, and their tension checked periodically. For general upkeep, clean the cameras and sensors monthly, wipe down the exterior housing, and keep the firmware up to date via the Yarbo app. If storing the unit, charge the battery for at least 15 minutes every three months to prevent inactivity issues. A seasonal inspection is also recommended.
  • Is there a warranty and support available?
    Yarbo robotic lawn mower offers a comprehensive 2-year warranty, 24/7 customer support, a 30-day return policy, and a 45-day replacement program—where we send you a replacement machine first and recycle the old one afterward to minimize downtime—ensuring a smooth, worry-free experience.
Specifications Specifications
Book A Demo
Specifications
Specifications
Setup and Installation
Installer Program
1 on 1 Video Instruction
Submit a Ticket>
robotic lawn mower
