Lawn Mower Battery Types Explained: Complete 2025 Guide
Robotic lawn mower and battery on lush green lawn, showcasing modern, efficient yard care technology.
When you ask, “What type of battery does a lawn mower use?” the answer depends on the kind of mower you own. Whether you’re maintaining a small yard with a push mower or tackling acres of grass with a riding mower, the battery is at the heart of reliable performance. A lawn mower battery isn’t just a power source—it determines how smoothly your mower starts, how long it runs, and how much maintenance it requires.
Modern battery powered lawn mowers are gaining popularity thanks to their eco-friendliness and low maintenance needs. But even traditional gas-powered riding mowers depend on durable batteries for ignition and electrical functions. Understanding the different mower battery types, sizes, and voltages ensures you choose the right one for your machine.
Why Lawn Mower Battery Matter?
Without the right battery, your mower won’t start—or worse, it may stop mid-job. The battery powers the ignition system, starter motor, headlights, and sometimes even attachments like electric PTO clutches.
For advanced robotic systems, the battery also dictates autonomous operation, long run times for extensive coverage, and reliable performance across multiple modules and extreme weather conditions. Choosing the wrong battery size or type can result in poor performance, reduced lifespan, or unnecessary expenses.
Common Types of Lawn Mower Battery
1. Lead-Acid Lawn Mower Battery
The most common type is the 12-volt lead-acid battery, similar to car batteries but smaller. They’re affordable and reliable but require regular maintenance, including checking water levels.
2. Lithium-Ion Lawn Mower Battery
Modern battery-powered lawn mowers often use lithium-ion batteries. These are the cornerstone of advanced robotic yard care, offering superior performance essential for tasks like maintaining large, complex yards year-round.
They’re lightweight, recharge quickly, and last longer per charge compared to lead-acid batteries. For example, a high-performance system like the Yarbo Core utilizes a 36V/38.4Ah lithium-ion battery. This allows for up to 4 hours of continuous operation on a single charge and supports wireless auto-recharging, crucial for autonomous tasks.
Beyond typical lawn mowing, these advanced lithium-ion batteries are engineered for extreme environmental adaptability. The Yarbo system's battery, for instance, can operate in temperatures ranging from -25°C to 60°C (-4°F to 140°F), with heating modules enabling operation as low as -40°C when powered on. This ensures reliable performance whether you're mowing in summer or clearing heavy snow in winter.
Furthermore, they offer rapid charging times, with a 30%-80% charge achieved in just 1.25 hours, significantly improving efficiency for continuous work across large properties.
3. AGM (Absorbed Glass Mat) Battery
A more advanced form of lead-acid battery, AGM batteries are spill-proof, maintenance-free, and provide consistent performance even in cold weather.
Battery Sizes and Voltages Explained
6-Volt vs. 12-Volt Lawn Mower Batteries
Most walk-behind mowers use 6-volt batteries, while riding mowers and zero-turn models almost always require a 12-volt lawn mower battery.
Typical Amp-Hour Ratings for Lawn Mowers
Amp-hour (Ah) ratings indicate how long a battery can run before needing a recharge. Smaller mowers may use 18–24Ah, while larger riding mowers require 35–50Ah for consistent performance.
How to Identify the Right Lawn Mower Battery?
Riding Mower Battery Requirements
Riding mowers typically use 12V batteries with higher CCA (cold cranking amps) to power the starter motor effectively.
Push & Battery-Powered Lawn Mowers
Cordless push mowers rely on lithium-ion packs ranging from 40V to 80V depending on the model.
Zero-Turn Lawn Mowers
Due to their size and demands, zero-turn mowers often require heavy-duty AGM or lithium batteries.
Battery Powered Lawn Mower: What You Should Know?
Advantages of Battery Powered Lawn Mowers
  • Eco-friendly, no fuel emissions
  • Quiet operation
  • Lower long-term maintenance costs
  • Push-button start convenience
  • Year-round versatility and modularity (for advanced systems like Yarbo)
  • Autonomous operation, freeing up homeowners' time
  • Exceptional performance on large, complex, and sloped terrains
Limitations of Battery Mowers
  • Limited run time before recharging
  • Replacement batteries can be expensive
  • Performance may drop in large, uneven lawns
How Long Do Lawn Mower Batteries Last?
On average, lead-acid batteries last 3–5 years, while lithium-ion batteries can last up to 7 years with proper care.
Signs You Need to Replace Your Lawn Mower Battery
  • Difficulty starting the mower
  • Dimming lights or weak electrical performance
  • Battery won’t hold a charge
  • Corrosion buildup around terminals
How to Extend the Life of a Lawn Mower Battery?
  • Keep battery terminals clean
  • Store the battery in a cool, dry place during winter
  • Use a trickle charger to maintain charge
  • Avoid deep discharges in lithium-ion packs
How to Charge a Lawn Mower Battery Safely?
Always use a compatible charger. For lead-acid batteries, use a slow trickle charger, while lithium-ion batteries require a manufacturer-recommended charger. Overcharging shortens battery life significantly.
For advanced robotic systems like Yarbo, wireless automatic charging systems are employed, avoiding direct contact and reducing risks of electric shock or leakage while enhancing charging efficiency.
Where to Buy Lawn Mower Batteries?
Lawn mower batteries can be purchased at home improvement stores, automotive shops, or online retailers. Popular brands include Interstate, Mighty Max, and Ryobi. Here’s a helpful external guide from Home Depot.
Environmental Impact and Recycling of Mower Batteries
Batteries contain lead, lithium, and other hazardous materials. Never throw them in household trash. Many stores and recycling centers accept used batteries safely and sometimes offer discounts for trade-ins.
Understanding what type of battery a lawn mower uses is essential for smooth performance, long lifespan, and hassle-free yard maintenance. Whether you’re running a traditional riding mower with a 12V lead-acid battery or a modern lithium-ion powered push mower, choosing the right lawn mower battery makes all the difference.
For homeowners with big, complex yards, investing in a powerful lithium-ion battery-driven modular robot like Yarbo can transform yard care, offering unparalleled automation, versatility, and freedom. With proper care and regular maintenance, your lawn mower battery can provide reliable service for years.
Whether you’re running a traditional riding mower with a 12V lead-acid battery or a modern lithium-ion powered push mower, choosing the right lawn mower battery makes all the difference. With proper care and regular maintenance, your lawn mower battery can provide reliable service for years.
  1. What type of battery does a lawn mower use?
    Most riding mowers use 12V lead-acid batteries, while modern push mowers often use lithium-ion packs.
  2. Are lawn mower batteries the same as car batteries?
    Not exactly. While similar, lawn mower batteries are smaller and designed for lighter loads.
  3. How often should I replace my lawn mower battery?
    Every 3–5 years for lead-acid and up to 7 years for lithium-ion.
  4. Can I use any 12V battery for my mower?
    No. Always check the amp-hour rating and dimensions to ensure compatibility.
  5. How long does a battery powered lawn mower run?
    Typically, 30–60 minutes per charge, depending on mower size and battery capacity.
  6. Can I recharge a completely dead mower battery?
    Yes, if it’s not damaged, but repeated deep discharges shorten battery lifespan.
